Rear window demister causing radio static
jonboy
I have a 2002 legacy wagon and everytime I turn on the rear window demister (button on ac unit) and am listening to the radio, I loose reception. Its not the stereo as I have just replaced it.
Any ideas? Also where is the aerial on this model? There is nothing external that can see.
I noticed this started happening in mine but only after installing a band expander. I have a kill switch for the expander as it hates my I-trip so I have tested it thoroughly and the static only happens when the expander has power. Is this the same for others.
Also Subieboy I think it may have been covered in the old forum but I couldn't find any post on this here.
I did try searching before I posted this but couldnt find anything either. The demister is 100%. Since the lighter jack causes the same problem when a phone charger is pluged in, I am guessing its an earth problem. I will try and track the earth wire and see what I can do. Failing that I will probably take it to an Auto sparky.
Guest lan_killa
you should not be running your head deck earth into the loom.... you need to run it straight to a peice of clean steel somewhere under the dash
