Help! wrx overheats up hills
My 98 sti goes mean runs sweet no issues just replaced the engine new coolant thermostat waterpump cambelt camseals evrything. except wen it gets to a hill. Heater stops going and temp shoots up in seconds however go down the hill or rev the engine on flat road and heater fires up again and engine cools quickly . Im not loosing water or blowing smoke. Any1 help me?????
Could possible be an airlock in the system? Has the coolant system been bleed when you put the new engine in? are the fans working correctly?
yeah i would have thought its some kind of partial blockage/air lock in the system.
It seems that when the engine is below the radiator etc the fluid is not getting pushed around to cool the system.
Fans work fine they come on as soon as engine temp rises above operating temp. Have tested coolant for exhaust gases and is clean so that rules out headgasket correct? Airlocks are possible but will that make it overheat up hills only?
Guest boostin
The fans only work at under ~20kph, or when the coolant temp hits 100 deg.
You will have either a monster air lock, or a partially blocked heater core. Try bypassing the heater by looping one of the heater hoses back and see if it still overheats.
Thanks all after tryng heaps to get air out of system had shitloads of bubbles finally appearing in the header tank bubbled for about 3 minutes and problem seems to be solved. Cheers
Guest boostin
 Bazza-NZ']
[quote name='boostin said:
Bypass the heater. I bet that's the problem.
+1
Most likley be the heater core
When you bleed the system did you run the heat on the hostest setting with full fan power?
You don't need to do that as they are constant flow, no matter what the temp setting is.
 boostin']
+1
OH..learn something new every day...
