02 rsk b4 boost problem
I have just bought a rsk b4 and after buying the car which i asumed was 100% standard the 1st thig i fitted was a boost gauge and to my shock the car is only makin 6psi (8psi if i reali push hard) this reading is with both primary turbo only and with secondary turbo runing as well surely this carnt be right?? I have spent hours lookin over the engine and can not find a leek anywhere and am nw stuck on were to go next. Are there any common problems that anyone knows of??
99% sure it won't be leaking the boost off it just not making it !!
Check waste gate actuator for being siezed ( passengers side )
Check to make sure restrictor still in the hose on the primary turbo pressure take off port for wastegate acutator/boost solenoid
Check vac tube plumbing
Na dont think it can be afm as car drives like a new one!! only reason youd know it has low boost is coz of the boost gauge I think it may have sumthink to do wid wastegate as when i take the pipe of and go for a drive the boost gets up around 18-20psi so may be warn spring in wastegate??
Carefull there, that's enough boost to destroy a primary turbo
Think you might need to go see a Sub Tech and get this sorted !! ASAP
I have a similar problem with my MY01 STI. was running 1.42 kgcm and now only running 0.6 kgcm. Have been freshening up vacuum hoses (crusty and brittle) and now running like a bucket of ... Anyway which restrictor was mentioned? Could a photo please be posted as I am now sufficiently scared that I have biffed this. Cheers.
The line that goes from the compressor housing to a "T" piece has a resitrictor in it
If now you have changed the lines and haven't fitted the restrictor then this is your problem
If your have thrown out the old lines then not much we can do for you here
We have a NEW contender for MUPPET OF THE WEEK hahaha
 Durty-Sanchez said:
It's a bit new to suffer from this, but the BOV could be leaking.. I went from 8psi up to 12 when I replaced my leaking factory one
I too had a leaky BOV apparently, or a dodge hose that was leaking on the secondary turbo so took it in to get it looked at, Mainly cause I had the check engine light coming on every time I went up my hill, Later on that turns out to be a O2 sensor.
Anyway coming back to the BOV took it into subspares in chch and they replaced the bov and a hose ( Because they tested them faulty ) and then replaced them with faulty parts. Argh.
Took it into Stubaru the next week to get the rear diff bushes done to it and he tested the secondary bov and hoses and said that they are still leaking. Argh FTL Subspares.
Well would like to report took my car to sub tech on thursday they had it for 2 day could find a thing wrong with it then just b4 i went to pick it up me and the sub tech took it for 1 last drive and to our suprise problem gone!!! Car is now back to full boost (15psi!!) drives like new! As to wat the problem was in the 1st place who knows??? ;D ;D
