Hi
wanting to swap over the rear doors and tailgate off my bg5 parts car onto my bg5
how easy is it to do this
I see rear doors have a plug for wires so that parts okay but how simple is it to swap em over
also i can't find a plug for tailgate wires so no biggy will re solder how easy with this one to do
reason for swap is parts car has tinted rear windows and cant be bothered just swapping glass over plus i need the tailgate glass as my rear windscreen demister wires are shot
want to eventually swap over cargo glass but that will have to wait until one of you guys that know what your doing are down my way (whangamata)
Cheers All
T1M0
The plugs are right down the pillars behind the tail lights. A right prick to remove too.
yup you gotta thread the plug back up pillar then guess what - thread it back down you good car! I cut a hole half way to assist with my swap, oh and get used to fibreglass in your skin from head-liner, you'll need to get it down in the back half for access to stop light stuff
Cheers joker
Have reached a rock though as can't afford to go to a glazier and now don't know anyone who knows what there doing with the removal of glass
As I want the windows from rear doors back as its already tinted wanna save me some pennys if i can as relying on the sale of some of my bg5 parts (hint hint)
Timo
you dont need a glazer to take out the side windows, the plates on the sides come off (rear one first) then top and bottom (check jokers side shot pic you will see the rear removed)
from there you will need a clay cutter wire to cut through the black silicone holding the glass in, use wedges to keep the gap as you cut through it, so it doesnt re-glue itself. (think there called versa wedges, wooden one do fine)
pays to you have someone help you, but patience is the key.
I say use clay cut wire as it's cheap and does the same job, you can buy windshield knife but if you cant afford a glazer you wont have the money for the windshield knife.
this is a windscreen wire kit
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200334175_200334175
this is clay wire cutter
http://www.dickblick.com/products/kemper-wire-clay-cutter/
good luck
Not sure about the tail gate,
but I'd like to suggest having a go at swaping the glass over. When I had to do it, I took the door card off just for a look (I was thinking about calling a mechanic minded mate to help) and then I ended up undoing a couple of screws and the window more or less wriggled out of position!
It would have to be alot easier to do then swapping the doors, as the doors need to be lined up well, when re-attached. They're big and heavy so would be more comfortably handled with two people. And like others have mentioned, there is the wiring that goes back into the pillar.
yeah
have asked about this one a few times
ideally i only need the rear glass as my demister wires are shot
 JoKer said:
JFGI "demister repair kit" returns a few options including conductive ink
thats new to me but where you buy them from
T1M0
 liltim']
T1M0
JFGI ;D
 boostin']
T1M0
JFGI ;D
Which is??
how did i know something like that was coming lol have already done that
would repco or supercheap sell the kits
you would probly have to ask someone who works at repco or supercheap now wouldnt you :P
-smurff
-smurff
No need to be such a smart C* about it
 ReubenH said:
JFGI = Just ****ing Google It
For reference.
Yea figured that out thanks Rueban
yea brain wasn't working all that good last night so clicked later on lol
thats a good one though will keep that in the back of my mind
never knew you could replace the wires with those kits so might ask around supercheap or repco see if they sell will post if i have some form of sucess
