Difference between STi and standard WRX's?
Ryan
Hey guys, I'm a new WRX owner (previously had a Forester STB 1997). Can anyone please tell me the main differences between STi WRX's and standard versions? What about engine internals, are the pistons forged?
Cheers, Ryan
much debate...
to put it simply,
sti=semi forged pistons
non sti-cast pistons
different turbos
different clutches
different gaskets
different inctecoolers
sti=usually headlight covers
non sti=fog lamps
some sti's have a bigger spoiler (depending on verson)
many other small differences...
not to mention the power difference... :-P
theres no debate.. just lots of different models, and lots of small things
GENERALLY on your usual STI these things are upgraded from the WRX model
rev limit
boost
ignition timing
engine internals
throttlebody
intake pipework
intercooler and pipework
turbo
injectors
clutch
flywheel
gearbox ratio
gearstick throw
differentials
halfshafts
chassis stiffening
engine/gearbox mounts
strut brace
suspension bushings
swaybars and links
shock absorbers
springs
ride height
alloy rims
brakes
inside/outside trim level
seats
window tints
exhaust
hmm some things still depend on the model and year. then ther's wrx-ra sti-ra and the type r's... then all the limiteds
short answer - if you can afford it, get the sti
rev limit
boost
ignition timing
engine internals
throttlebody
intake pipework
turbo
injectors
clutch
flywheel
gearbox ratio
gearstick throw
differentials
halfshafts
chassis stiffening
strut brace
suspension bushings
swaybars and links
shock absorbers
springs
ride height
alloy rims
brakes
seats
window tints
exhaust
"much debate" was refering to the pistons... as i called them "semiforged" and couldnt be bothered with people flaming me for something along those lines
