cams install
hey can anyone recommend a place in auckland to put cams in a sti. i hav bought a set of hks cams and dont really know how much it would cost to put it
 capster said:
hey yes i am in central auckland (epsom). and will i need a retune since i am running a link?.
if yu have gottin larger or different profile cams, then you will most likely need a retune to gt the most out of them. if they are massivly different then a retune may be nessassery for idle and or stable running
-smurff
Absolutely definitely. And yeah, cams are a fairly DIY ish job. BUT, ask questions here first on what needs to be done, chrisjunkie may have installed factory cams, neither of us have even touched aftermarket stuff.
What engine do you have (EJ20G, EJ20K, EJ207 etc.. and from what year). And do they run different clearences or what. Ring around various engine builders for some info on the job, even try PBMS (Possum Bourne MotorSport).
 Stoffa said:
If you dont know dont try it yourself. Pay someone to reshim your clearances properly.
This is absolutely correct, likely the valves will have to be lapped back slightly, and the valve shims will DEFINITELY need machining if you have solid lifters.
 Wiretap']
Exactly what I had to do with mine. Lucky I had Ryan (boostin) help me out with what they need to be and was able to get them machined by a precision engineering company. VERY important to get right!
