Legacy BE5 to V4/V5 STI engine/gearbox conversion
Hi all,
My MY2000 B4 TT tiptronics done nearly 200k andwondering if I should just do another 100k service or convert my car to STI engine and gearbox off V4 or V5.
Also, if I do decide to go for STI conversion, approximately how much would it cost all up including parts and labor?
Cheers :)
 stevolution said:
Hi all,
Cheers :)
use the search function..
And you have to use version 5/6 engine. 4 is different loom.
Do you want to build from sratch or just take a complete running set up? thatl drive your cost
Hi thanks for the reply. Hm, I did try using search function but came with alot of irrelevant hits.
When you say "build from scratch", do u mean doing up all the internals as well? I think im just looking to replace with a complete running set up.
So how much am I looking at if I'm looking to convert from a complete running set up?
Just looking for rough estimates so I could decide whether to get a new car or convert.
With a complete running setup, you do run the risk of buying a dog though.
Its probable yours need a rebuild now, so decent budget with a new bottom end and reco'd top, single turbo conversion? Not a lot of change from 5 grand? Keep the old bottom end and get reco'd perhaps around 3g?
Depends what your heart is set on. Im guessing you are prefering to go single turbo / manual conversion. Think of a budget and double it :)
