Can't remove sump plug
aim
Didn't work - well, I don't have a 6 point socket and I banged it with a chisel a few times, even tried a screw driver. But I'm still just rounding the edges off the bolt...
I do have one of those 12 point sockets (its what I'm using) I could find the appropriate screwdriver.
Someones probably left the old crush ring on the plug and had to tighten it LOTS to make it seal. New plug and a new crush ring should stop it happening again.
ok got a new crush ring. But same plug - mechanic thought I hadn't damaged it too badly. So cars good to go! sort of,
I should make a new thread, but I feel I've made enough recently I've found a loose hose which is next to my secondary downpipe. There's no point in which it looks like its come unplugged from. But its random as... I've got a photo I'll post soon.
Other question is, I've asked a local guy about my power issue whos done a number of TT to T conversions. He told me to pull of the hoses from either side of the turbo and wash with diesel/degreaser as the fluid bearings maybe clogged up. then after that I should pull the hoses off the side and blow very gently some compressed air into the turbo to check it spools. Thats all fine and dandy... but which hose!? I pulled one but water came out. He's now gone, lives out in the whop whops and can't really get hold of him until tomorrow - I'm pretty busy tomorrow and I want to get this car on the road by friday! So I was hoping I could do this tonight. Can anyone help me?
He's also offered to sell me some larger turbos off an 03 quite cheap if ones rooted. Or both. I assume if I up one, I need to up both? As it'll cause back pressure on the other charger?
