Fuelling Problem
nt_a_foz
So took the RS out tonight to check its running fine..
Got half way around the block and it died.
No fuel coming out at the engine..
Toook the fuel pump out and it works when hooked straight to the battery
Plug under the rear seat isnt burnt out.
No power at the fuel pump plug or the plug under seat, its got constant power under the seat but no switching power.
Any idea what this could be or which relay is the fuel one ??
  • Replies 52
Shit is the starter strong enough to turn the car over??!! Most just turn the engine....
Nope, starter circuit is independant of the ECU.
I was going to ask if the CEL came up, but Link, so yeah nah....
 Ichi Ban said:
engine been out, then check ECU earths on manifold !!
yea i have had this problem once before, however brad didnt you say you drove it half way round the block? that would meant that it was running to begin with right?
if it was the ecu earth it wouldnt start at all.
 driftrex']
loose wires can cause a multitude of things -
 Ichi Ban']
good point, probably the best place to start as you did have the engine out brad.
 driftrex said:
its not gona start anyway, after thinking bout it though im not sure it will throw any codes without the engine starting.
will throw codes in stored in memory !
 Ichi Ban']
the ones stored from the previous car it was installed in right?
so thats no help. what if you reset it, would it pick anything up without starting, if there was a problem it could pickup?
