Fuelling Problem
nt_a_foz
  • Replies 52
there are two heavier gauge wires in the loom plug under the rear seat
One ( black with red trace from memory ) is the power feed from pump relay
the other ( black ) is earth !
I suppose i could swap the pump setups to try it???
I havent tested ignition turnoff myself but the boys were on the multimeter last night and reckoned there was no power there.
But when i tested tonight jsut with ignition (by myslef so cant do ignition as well) it was showing 2 wires with power one with 10.8v and the other with 6 or so volts
Yup those 2 were under there when i looked tonight...What baout them??
you just told him, well my crystal ball didnt know that !!
Boosty, can you not see that i am trying to help some one here, with step by step logical process
or do you still want that crack I promised yoiu earlier in the year !
I WILL be in TGA next tues if you do !
OK
I have a life and its proven in that article, gee boosty maybe i actually know what im taking about
Seems you just dont like me helping people around here, really should I care if guys cant fix there own cars, why do i bother even messaging others with proven advice and offers of help
Accept the fact that on somethings I know more than you (ie Subaru's ) and other things you know more than me ( ie hydraulic hoses and fittings )
If i went on a hydraulic hose web forum and started being a COK then I would be the MUPPET
PS thanks for the free advertising :)
Alright boys calm down..... ;)
Adam what you doing tonight???I need antoher set of hands to test the pump feed...
Girls will get bored of that in like 3.5seconds haha
Might try swap the pump 2...
If theres anything else that crosses your mind ichi let me know im open to all ideas as starting to get a bit annoyed with it lol
Testing wiring alone can be fun :)
try and start the car, after cranking it listen for the pump relay to "click" out, approx 2 sec after you have been cranking
This will tell you if ECU is operating the pump relay - this eliminates a whole heap of things and narrows down your search
run a direct power feed to the pump from the battery into the pump wiring plug
and run a seperate earth also. if pump still no go then replace it !
have sent you a pm with my contact # if you want to call
I was testing the plug under the rear seat on the engine side not hte pump side so that shouldnt be a problem should it??
That was what i was going to do last night but didnt have a long enugh bit of wire...Might do that tonight..
I swapped the pumps this morning before work and it didnt do anything either..
Guest itsgotgo
Did you test it at the link brad?..not that i now half as much as the other guys here :)
I never knew sorting a fuel problem could be such a wee,ing match.
Nah not yet...
Adam and Brenton are going to come round again tonight and well try sus it out..
Im pretty sure itl be a wiring issue....Just a pain in the arse more than anything just want the bloody thing to go so i can take it for a wof haha
Edit : 1994cc post lol
