Fuelling Problem
nt_a_foz
Well we found the problem......
There was a main big fuse blown which we hadnt picked up in the dark the other night..Must be the ignition one.
Replaced it adn car poped into life for a second the fuse blew again...
So replaced it and car run for a minute or so then died again.....
Noticed smoke coming from the corner..Turns out there is an unsued plug..minus the plug so just the metal connectors and had been touching the chassis and shorting out..
Run out of fuses now but should of fixed the trick and itl be mint...
Was something silly after all ::)
  • Replies 52
  • Created
  • Last Reply
Top Posters In This Topic
For a tempory fix as nothings open at 7pm for those things we went to dick smith (late night thurs) .
And bought a 30amp fuse holder and got some spade termials adn a normal spade type fuse and run that...works mint...
Just blanked off wastegate and put silencer in so it can go for a wof tomorrow..Fingers crossed itl pass
