Fairly serious cambelt question... Thanks!
keeweechris
Car: 97 wrx
I'm on the homeward leg of a my 1st cambelt change, but I'm not 110% sure its ok.
Firstly, when I thought I had it all lined up (lines, notches, nicks, as per service manual) I pull the pin on the tensioner (swing-arm type) and not a lot happened. I expected the tensioner arm to jump out and the tensioner idler to put more tension on the belt, but nothing happened. In fact, I can still just wedge the pin back through the holes to the back of the tensioner.
It was a brand new part from Winger.
But the belt isn't slack anywhere. Not sure how much tension there should be on the belt though.
I'm really scared that if I leave it, and the tensioner is faulty, then... well you know what.
How can I tell if the tensioner is working? Has anyone had this before?
Thanks!
to check the tension on the belt, find the longest un interupted piece of belt, i.e. where theres no idlers etc. and see if you can twist the belt 90* perpendicular to itself. this is about the correct amount, other than that. wind the bolt back in and turn the motor over by hand and see if the tensioner comes out a bit more... it will over time
Normal as. Just wind the engine over by hand a few times and make sure all the marks line up again. The passengers side normally looks about 1/2 a tooth out too.
Yeah, that was my other concern, the pass side double markers don't line up properly, and the top marker is kinda 1/2 way between tooth and valley, and doesn't line up nicely with line on new cambelt. All feels a bit rangi, but any other config is worse. I've read somewhere else that this is normal. Weird tho, and a bit disconcerting.
OK, re tension, the longest length between pulleys is between tensioner and pass-side intake cam pulley. Twisting this hard by hand I can almost get it to 90degrees but not quite. Seems fairly tight. The tensioner retracts a little bit (0.5mm) when I do this, but moves back when I let go.
I'll leave over night, and maybe it will settle.
Cranking engine over the correct way is all fine and dandy, but I'd have to crank it over 1000 times to get the lines/notches to match up again. I've read its not ok to turn it backwards... is this true?
Good to know your ones boostin and dimin have done the same. I'm prob just over reacting, but its strange noone mentions this in the writeups of cambelt changes.
Thanks guys. I'll stop pestering you soon.
