Does anyone have the pinout info for the coil pack igniters??
I've decided to try a matched pair of coil pack and igniter to cure my hard starting fault.
But I need to rewire it from the dual plug ignitor to single plug. Anyone got the info??
Wiring is easy, there's nothing to it. I can help you wire it up if you want.
Basically you got your 4 ins (ECU signal), your 4 outs, and power or ground, i forget which. You just make that into 2 ins and 2 outs and the spare wire. Presto. Cyls 1 and 2 are joined, and 3 and 4 are joined, but you knew that. You should be able to colour match wires even.
I know how to do it, I just don't know what pin does what on the new ignitor. Don't worry about it anyway, the whole idea has been shelved.
Ah well, that's a shame. It has been done before, so you know it is possible.
I actually had an idea on the way home after talking to you today. You mentioned it'd be best down by replacing the whole loom, and F-that for just an STi ecu. But maybe you don't, maybe just changing the sensors is all you need to do. New TPS, cam/crank angles etc. etc..
That was if you were determined to get it done, but given the price on that possum link... :D
Yeah its out. Pissed me off one too many times. If Drunkenmonkey doesn't pick it up to try in his bf this weekend it will all be up for sale.
 ReubenH said:
I think he said it is, but if you want it for that BG in your sig, it won't work. BG/BD 4-plug is totally different to BC/BF 4-plug. :( Same plugs, different pinout.
yea but is it coming out because it wont work or because its a pain to get to work?
 CUDDAS said:
Hey i'd be keen to get some wiring diagrams or some plug pinouts to identify to swap around, as the one's i've got are getting confusing as they have different wording for the some of the same sensors :)
lol, I am having the same problems, lol
As long as you know stuff like MAF=AFM, and duty solenoid = boost control etc, you're sweet.
The adaptor appears to be a working item, the problems seem to exsist with the 3-plug ECU talking to old sensors or something like that. There's more to it than just an adaptor. But obviously we've gotta address these other things in order to make more adaptors and sell them.
 CUDDAS said:
This will be a very dumb Question but can someone please let me know what IIRC stands for.
& thanks that mean's i'll be looking for some V3 sti engine sensors from the wreckers
I reckon you need a full loom, from the sensors right back to the ECU.
