Auto to manual conversion
nt_a_foz
 nt_a_foz said:
nah looks like the brake and accelerator are on the sasme i undone 4 bolts and aint falling out lol....
Clutch seems to be on seperate
yup that is right
clutch seperate
u may find that all three are better as the manual has a smaller brake pedal :)
undo the 4 nuts around the brake pedal and the 2 on the accelerator pedal, then take the throttle cable off the pedal end and undo the clips on the brake pedal. Then theres 2 more bolts that go up above the steering column.
THEN it falls out. Gotta change the brake pedal or mr WOF man gets angry
Yeah I had a cut down auto brake pedal after my manual conversion and to be honest it was a right bitch to drive. The pedal still sits too close to the clutch and I kept catching the side of the brake pedal when jumping on the clutch.
Pedals are cheap from Pick A Part though.
  • 3 weeks later...
hi guys. nim ew here and was hoping for a lil advice. I have a 1998 GTB wagon, in manual(94-97 shape). long story short, when i bought it i bought a lemon. i am wondering how expensive/time consumming/hard it would be to take my manual box from wagon and place it in a 1999 B4 RSK sedan? its currently tiptronic. can anybody point out places to go for help, any hidden tips and or tricks? also approx cost to undertake a task like this
Much apreciated :-)
im in wellington, well lower hutt to be exact. i will post in intro as suggested. and in regards to the VDC, no its not. its a 1999 B4 RSK sedan.
 2retz said:
wow guys, thanks for all the offers, is there anything i need to do ie purchase before undertaking a task like this??
well the pedal box, the new gearbox mount, clutch, master cylinder and assosiated bits, different drive shaft, gear shifter.
Keltik - what else he need?
all stuff found on CS easily enough.
Flywheel, starter motor, gearbox, clutch kit, clutch hydraulic lines, clutch slave and master cylinders, brake pedal assembly, center console surround, new dash cluster (or modify old one) new ABS pump (or leave TCU in place), prop shaft, manual ECU, gearbox and mounts, 12v relay, some wire.
Probably more little things im not thinking of.
