B4 - Airbags dash light and PS light?
Optical
What makes the airbags light come up?
I also have the power steering dash light lit up
Ive just swapped steering racks, would that have anything to do with it?
Also the B4 steering rack has some sort of sensor on it. Anyone know what it is? Ive tried shorting the old pins and a few various resistances across the plug to try and trick it, but no luck?
The sensor is for the variable assistance.
I can't see a rack change bringing up the ABS light though. Have you checked the ABS fault codes??
Ah, I'm guessing you've popped the clockspring then. Does your horn still work??
Yeah separate ECU, usually bolted to the steering column. Not sure how the variable thing works. I've never looked into it TBH.
PS - Ive put an inpreza quick rack in. The legacy rack has some kind of 2-wire sensor on it which the impreza rack lacks. Now the PS light is on and I presume this is because the old rack plug now plugs into nothing.
The legacy rack is a short circuit with no pressure to it. I dont know what happens when it gets pressure, but presumably the resistance across the sensor changes. Ive tried a few resistors across the plug in the car but havent been able to get the light to go out. So i just need to know what the sensor characteristcs are so i can fool it.
I found a b4 yesterday but couldnt even find the wires coming up off the rack...
On a side note, how do i take the airbag off the wheel? Does it pry off or unbolt somehow?
  • 3 weeks later...
The clockspring is that round thing with the yellow label. The horn won't work as it is now unplugged, and the SRS light will be on as you have the drivers airbag out.
 Optical said:
That bit of wiring hanging off to the RHS from the back look like the problem. It looks like its been ripped off the back of the clockspring.
As for the headlights not turning off, not sure sorry.
