91 Rs TPS adjust (how to?)
minsu515
Set it so the signal wire is giving ~4.7V with closed throttle. It should also be right where the idle switch opens and closes.
Just turn the ignition on, but engine off, and probe the wire. Supply voltage is about 5.2V from memory.
