Peoples opinions please
neodowd
We have had our forester for about a month now, It has wind noise from door/ window whilst driving and gets worse the quicker you go.I have looked at the seals but nothing obvious. I have been told that subarus have a history of this but my other two subbies I owned didnt. The question is do I live with the noise or complain to the car dealer? cheers
I have exact same problem on my front passenger side, at speed can here the air 'whooshing' (sounds like when you have window down a little bit). Really cant figure out whats causing it though because seal looks in mint condition.
Anyone solved a similar problem before?
here is an old trick that i was told about,about 10 years ago way back when,
what causes that noise is the weight of the mirror slowly bending down the the sail that it is mounted to ....
so if u open door and wind down window and gently lift the mirror it will help
it does take trial and error until u get it high enuff to close the gap :)
All fixed no wind noise yay!!. Thanks to your guys advice i just wound down window, opened door, placed my knee under guset ( triangle bit with mirror on outside) and pulled forcibly towards me for 10 seconds .the window is now realigned so it comes up against the seal tighter. cheers guys :D
