The sub
kingersman
Ok guys the sub has been off the road for some time now and after having a look at it many times i have found these problems
compressions came up as : 150 125 115 and 95
some dick had pluged in the diagnostic cables....
some of the mountings on the kit have started to go.
battery is pretty much F***ed
no o2 sensors and plug just sitting there
so whats your point? lol... compressions will be low if the engine hasnt been turned regularly, if it will run just idle it for 10 minutes etc... then re check. sometimes rings can be sticky or slight rust in bore isnt uncommon.
agreed, do you just want someone else to know or want some advice or help or what?
 kingersman']
yeah it is a wrx.
just wondering how bad it really is having low compression like that
[quote name='boostcut said:
so whats your point?b] lol... compressions will be low if the engine hasnt been turned regularly, if it will run just idle it for 10 minutes etc... then re check. sometimes rings can be sticky or slight rust in bore isnt uncommon.[/b]
