Crunchy Gears at high Revs/ Cant get into gear!
Lynx
Fluid was changed about 2weeks ago. Flushed/bled the system.
 boostin said:
Yes the slave can cause your issues. If its cheap enough, then replace it. Some are $40ish, others are $200. Ring your local dealer with your cars chassis number and check.
Are you 100% sure?
Thanks for the replies.
  • Replies 60
 Lynx']
Are you 100% sure?
I haven't looked at your car, so no, I'm not 100% sure. I do know that the slave cylinder CAN cause those sort of problems.
whts if i dont know the chassis number
-smurff
 smurff']
-smurff
How so?
well the manual box isnt out of my car, nether are the brakes, so i cant give the number to help them find the parts i need
-smurff
-smurff
Do you know what the box is from? Revision number and all?
 boostin']
-smurff
nope
-smurff
I have the same problem. Dont have the chassis number for the donor master or slave cylinder... But have a high engaging point on the clutch
i took in the slider pins off the 4 pot brakes i got, to get new nice clean ones, he was like, err chassie number?
i really wanted to say just pick one with 4 pots and we will see if there the same pins.
-smurff
