Jono24
Jono24 last won the day on October 18 2019
Jono24 had the most liked content!
1 Follower
    Christchurch
    Mech Engineer
Jono24's Achievements
Motormouth
Motormouth (4/7)
303
  1. Who's doing your cnc porting, kelfords? I hear Hartley now cnc port ej20 heads too. Sent from my SM-G960F using Tapatalk
  2. Never mind, car sold Sent from my SM-G960F using Tapatalk
  3. Hey Guys, Is anyone in auckland able to look at a car for me? I think it is on the north shore. Cheers Jono Sent from my SM-G960F using Tapatalk
  4. When the bolt is in there, not much is going to go down there. The extra machining time to remove that material is marginal at best and it removes a bit of unnecessary bulk. I can ask the machinist, but I don't believe this will have a noticeable impact on cost as it doesn't affect part turns in the machine or tool changes, or much in the way of tool paths.
  5. Hi All, I'm working on a CNC machined TGV delete to be used with v7 STI intake manifolds. I've modeled the part myself based on a factory aluminum TGV and had it 3D printed and test fit. The design will allow for standard Subaru injectors and rails for all injectors ports, this allowing flexibility when building up your fueling system (i.e. aftermarket injectors or rails for Subaru v7 Imprezza STI will fit in both lower and upper locations, along with factory v7 injectors/rails). The benefit of dual injectors per cylinder is when you are chasing big horsepower, and a large single injector per cylinder (i.e. 1500cc and above) will achieve poor resolution at part load/cruise, resulting in a stumble or accelerator hunting at cruise. With twin injectors, you can retain the factory injectors for low horsepower duty, and allow the ECU to bring on the secondary injectors only as needed, thus providing factory levels of fueling control at low engine load and adequate fueling for high horsepower runs. This design is intended to utilise your primary injectors in the lower injector ports for general duties, while the upper injectors provide additional fueling as required. This will require an aftermarket ECU to control the additional 4 injectors and it is best you consult with your tuner if your ECU is capable of managing the extra 4 injectors. I'm currently working through the adapter for mounting the upper fuel injector rail and pricing with a CNC machinist with the final version to be cut from aluminum billet. As you will understand, the bigger the batch of these the lower the final cost, so if anyone is interested please get back to me via private message and I can put you on the list. I'll post some pictures up here shortly of the 3D printed version, but please be aware that this isn't the final product, as details such as fillets will be added to improve machine-ability and reduce costs. I'm happy to answer questions anyone has, just fire away. Cheers, Jono Sent from my SM-G960F using Tapatalk
  6. If anyone has a Holset HX35 service manual that'd be much appreciated, I can't find one online anymore.
  7. Hi all, Here's a link to various FSM's I had been asked for from a forum member. ***Disclaimer*** These aren't my work and aren't all from Subaru either. Some of these are re-posts of info made by other members from this site. https://drive.google.com/folderview?id=1-vgCUJF91RRrq_tmuh2KcB-VqrDmt3Rn Sent from my SM-G960F using Tapatalk
  8. I vote efr7163. I'd prefer a water cooled turbo next time (not many holders are water cooled). Sent from my SM-G960F using Tapatalk
  9. I've had one replaced by Novus in Christchurch ~12 months ago, used far to much adhesive and it was visibly messy around the A pillar trims.
  10. The initial post asked if he could fail a wof. The answer is yes. And there is misinformation being disseminated here. Likelihood of getting away with it is something else, and he has a good chance of getting away with it. Then again, with the tightening grip on wof inspections it may not last long. Sent from my SM-G960F using Tapatalk
  11. https://www.lvvta.org.nz/documents/suplementary_information/LVVTA_LVV_Cert_Threshold.pdf It explicitly says (page 12): 11-1 "Note: LVV certification is always required for the fitting of a turbocharger as a modification, or the upgrading of a turbo or waste-gate." Interestingly it says you'll need one if the fuel type changes, which I would assume includes ethanol/flex-fuel (13-2, page 13).
  12. Sorry to hijack, but what additional info do you get from measuring egt over egbp (or vice versa)? Is one of them more useful than the other or better bang for buck (so to say)? Sent from my SM-G960F using Tapatalk
  13. I think you are making the right call to go to the link. My conversions have been on a be5a with a wrx a7 ecu and my current be5d with a v3/4 plugin link, and although the wrx ecu went well, the link is a lot more flexible. This is particularly so compared to the early jecs ECU's. If you go to pick a part you could probably find a 4 plug ecu and a set of '3 plugs' and make an adapter on your bench which makes it heaps easier than trying to work in the footwell, this can help if you find a bargain on a plugin for a different model. Sent from my SM-G960F using Tapatalk
  14. https://www.caranddriver.com/news/a15344939/subaru-recalls-100000-cars-for-smog-pumps-that-could-melt-and-catch-fire/ And the NZ recall, although Exiga isn't listed, I'm guessing this is because it wasn't officially sold here. https://www.recalls.govt.nz/recall/subaru-forester-impreza-legacy-outback-wrx-model-years-2007-2014
  15. Isn't that the emissions air pump thingy which works at start up to make the exhaust cleaner? (or something like that) Have you checked to see if there are any recalls on your model? Would be worth a look i reckon.
  • Who's Online   0 Members, 0 Anonymous, 129 Guests (See full list)
