JGM
JGM last won the day on December 8 2022
JGM had the most liked content!
4 Followers
    - JDM 05 5MT BP5 GT -
    X NZDM 08 5MT BP9 OB X
    X JDM 91 5MT BF5 GT X
    X JDM 03 5MT BP5 2.0R X
    AKLNZL
    QS
3,460 profile views
JGM's Achievements
Motormouth
Motormouth (4/7)
481
  1. Would recommend Subtech in Penrose. Bit late to the party, is this seriously the last post in the Auckland thread... Jeez
  2. For old times sake - hope your pants stay dry. https://www.instagram.com/explore/tags/lowtback/
  3. Just drop it on its guts ?
  4. Nah dude, no longer have the old girl...
  5. Nice work behind the lens mate @ACE3.0R
  6. NZ new 2008 BP9 Like these? Not factory so been switched at some point in its life...
  7. Not uncommon on the JDM models. B4 are sedans only... Colour: Grey
  8. Any BP towbar will work, same chassis from 03-09. This is the case with the vehicles tail lights, unsure whether the same applies to trailer LED tails... I had a factory fitted towbar on my old wagon, didn't appear to have any flash wiring associated. Might be best to push on and deal with the issue should it arise instead of resolving an issue which may or may not exist.
  9. As previously mentioned, the wheel offset is reasonably low and is what's causing the rub on the inside of your outer rear quarters. It's the best place to start, failing that there are some other options but would be good to avoid if possible as it sounds like you just want to remedy the issue and are not intentionally modifying.
  10. JGM
    REDMANE
    Speaking from my experience with 4x4s here; Anything regardless of the overall lift size by way of spacer requires a certification... Anything with increased ground clearance up to 50mm by way of spring lift (ie. lift springs on factory or replacement struts) does not require a certification. If you're going to do it, go for a spring lift - far far safer...
  11. FYI, you’ll burn through RE003s in a year or less if you don’t correct the camber, speaking from experience here ?
  12. Ughhh I can't remember exactly ? you'll be pleased to know that the Legacy struts are 40mm shorter than the OB, good drop there without even considering the springs!
  13. @ride Subtech are excellent, have used them for all my cars as I know the owner personally.
  14. @iludez Legacy & Outback suspension is interchangeable yes. You will need to either a) cut the OB bumpstops or b) source some Legacy ones from a wrecker (I've actually seen them brand new on TM too) as even a moderate drop will cause clearance issues there... Depending on how long you want your tyres to last, I'd recommend getting some adjustable rear camber arms (upper control arms) to correct the camber as even a set of Legacy struts will set you at approx. negative 1.5 degrees. Other than that you'll be away laughing. I still miss mine, handled so bloody well with all the suspension upgrades I'd done. Goodluck!
  15. My mechanic (Subtech Performance Services) uses Zic, never questioned his judgement nor had any issues
  • Who's Online   0 Members, 0 Anonymous, 99 Guests (See full list)
