Content count
8,033 -
DRFVDR last won the day on September 25 2016
DRFVDR had the most liked content!
119 GreatAbout DRFVDR
Rank
Moderator
- Birthday 06/12/67
Drives :
25 years as a diesel mechanic and subaru owner has taught me a few things :)
Interests
Motorsports( rescue), fireservice(volly),electronics(mmmm toys) and family ( it is to large)
Location
Raetihi
Occupation
Diesel Mechanic/Business owner
DRFVDR started following New Member with 81 Leone
Nice sedan,sorry to inform you it is well overpriced though if it was a, 81 Brumby with that miles on it, it may be worth that
DRFVDR started following Tyres for daily driver? (BPE 3.0R)
I run the Hankook Ventus on the Hilux, Love them, very very good in the wet and the dry, Have not had an issue while pushing the heavy pig hard, I get bloody good milage out of them ( 60,000k) and drive them on every thing from heavy snow to loose Gravel. I rate them high
DRFVDR started following JDM smart keys?
The issue I can see you having is the programming of the key, with the right equipment it should be able to easily do it, buy a unprogrammed blank from ebay ( make sure it is a complete blank including all the electronics) then using what ever is needed to program the key to the car and done. The unit to program the key is the issue, I have just done this to our JDM 2008 Vellfire, the smart key was available from Toyota at a reasonable price ( $200 ) so I just bought that, I may of been able to get one from ebay but a/ I could get it the next day b/ 100% sure it would work c/ wanted to still have the abilities from the original remote ( twin electric side doors). I then plugged in my Gscan 2 went to the correct option followed the instructions on programming the new key.( took about 30 seconds) and was done. Seems simple enough except the Gscan2 is a $12,000 unit.It would program the key for your subaru, not sure if there is a cheaper unit that will do it.
Well I done did it Narva has just released a h4 ( and Think a H7 ) LED upgrade kit Part Number 18004, Not as cheap as the Ebay ones BUT a/ it goes on to my BNT account b/ has a 3 years NZ warranty and c/ Can order today and it is here tomorrow. 12v/24v Dual Voltage 6500 k Colour 4000 lumens Passenger LED driver Halogen Both LED ALL THE LEDS
Simple really fill it up and then top it up every few days. depending on the age of the vehicle BUT you may be able to use a bluetooth OBD dongle and an app and you should be able to see how much fuel is in the tank
DRFVDR started following Need a solution to my fuel gauge!!
Going on what Boostin suggested, Anything Electronic in Nelson also does cluster repairs .
52" Led light bar mounted on the roof of my LUX
Yup trying imgur as well, can you see it now ?
Yeah I am having issues with trying to get google photos to show
As good as this ?
Will be good to Know, Want to do it to the 'lux and have a plan for the Brumby as well
DRFVDR started following Having issues with 5th gen HIDs? Read here
How "legal" are the LED headlight conversions ? I know the HID upgrades are WOF fail, guessing the Led upgrade are all ok if you are doing it IchiBan ( hehee )
DRFVDR started following Tyre sizes vs Speedo reading error
Most manufactures program in a small under reading of the speedo head ( so there is no comeback on them for speeding offences) most are 10% under. If you get the speed reading from what the ecu sees you will find it is pretty smack on with your gps reads ( as long as you are running a similar size tyre to factory)
You can buy new steelies out of OZ upto 15" but not overly cheap ( also can get alloys but will cost in excess of $1000 for a set) @DacerX is doing a 5x 100 conversion on his RX11 using the parts from an XT6 you can redrill your hubs to 6 stud and use pretty much any 4wd rim other than that you are pretty screwed, I have a couple of sets of 14" i scored of trademe but there has not been much on there of late.
- 5 replies
- 1986 leone
- wheel adapters
(and 1 more)
Tagged with:
Pretty sure my G-scan 2 will connect but at $11,500 It had better, I have a snapon solus ultray which will connect as well, all yours for $4500
Who's Online 0 Members, 0 Anonymous, 7 Guests (See full list)
