WANTED: someone in chch to wire up head unit.
Guest iceboychch
 iceboychch said:
having some issues installing double din pioneer head unit in christchurch...
anyone handy with a soldering iron and wires?
what bits are you wiring up etc? If you go to repco - you can get almost all style harness'es for stereo's for under $20. No wiring required - or soldering.
Just say what car you have and what stereo and they have them (usually).
Guest iceboychch
yeah tried that.
i have the harness they were selling.
unfortunately the muppet who previously owned it cut all the wires...
iv tried connecting them up to match colors but still nothing and iv tried 2 other head units with no success
 iceboychch said:
yeah tried that.
I'm guessing from your post that you mean that they have cut the wires in the back of your dash on the car side of the harness. It is going to be tough figuring out which is which. Perhaps a wiring diagram is what your after, RS legacy right?
Guest iceboychch
cool cheers ryan, i think its not getting power.. tried running wire from battery but no luck.
grrr.. damn muppets and their cutting wire techniques!!
Get a multi meter. Find your power and earth plug your headunit in then focus your headunit to a speaker. Should have a slight power up on that wire hence sending signal to that speaker. Go till its working. Thats how i do it if it all been cut off. Dunno if thats so easy to understand reading it back though :(
Colours are - and function:
Thick black - Ground
Thick Yellow/Red strip - Acc
white/yellow strip - illumination
thin black - illumination gnd
Blue/red stripe - +12V constant
White - auto antenna
Speakers:
Front (L): (+)brown/white, (-)green
Front ®: (+)red/yellow, (-)white/black
Rear ®: (+)blue/green, (-)red/white
Rear (L): (+)white/red, (-)red/black
NB: colour coding is known to change slightly even in the similar year models, the above is a general indication from a Ver 2 wrx loom i have sitting around...i've found the speaker wires to be generally consistent so that's a starting point.
ahhh just remembered... i worked on a mates 1990 gt legacy...
subaru changed to a single plug loom 1993 onwards, so prior to that 1989-1992 they used the two plug system with the power and speakers separated... i think the colour coding was very different too!
Post up ur wire colours... personally i would standardize the colour coding
i.e.
Black for ground
Yellow for +12V
Red for Acc
Blue for Antenna
Blue/white for Amp remote wire
Orange/white for dimmer
White for front left speaker
Grey for front right speaker
Green for rear left speaker
Purple for rear right speaker
Thats' what i did to my mates car anyway which had the plug chopped... i just soldered the above cables on used heatshrink and terminated with bullet terminals - it makes changing headunits a breeze too!
Guest iceboychch
Cheers to hopai for fixing my sounds... :D
that multi meter came in handy!
now to attack the parcel tray and stop the vibrating speakers!
 iceboychch said:
yeah sort of.. no memory.? its goin tho so thats the main thing.
I can fix that sometime if you want, just need to run a constant feed line from the fuse box because some previous twat butchered your wiring!
But yeah, 8:30pm in the cold is no place for running new cabling.
