Popping like it's hot!
So I recently had some different struts put in my car, afterwards I noticed a "popping" type sound in the back.
Mate checked it out and found the nut on the shaft was loose, so we tightened it, and less of a sound, but still there.
Took it to a place today, thought they would tighten it some more for me (rattle gun?) unfortunately this didn't fix the issue, and now I have this picture for you (spot the problem) Yes they tried to tighten other things too...
/Discuss /Laugh at me.
Guest loren
no reason for them to be too tight. the sound you hear is probably the shock sticking in the strut. Very common with rear WRX shocks being so long. You'll need to take them out again,
take the shock out of the strut casing... clean and grease with some light grease.
I have to do it regularly :(
Yeah I was looking at him tightening things through the back window.
I know the moment when it happened, and the whole time when he was doing it i was thinking "I don't think he should be using a rattle gun for this".
But I never checked it until after I left, the cap was put back on it too :o so when I took if off and saw that, well, y'know...
No. No he REALLY shouldn't have been using a rattle gun for that. :o :o :o>:(
 Shale']
I know the moment when it happened, and the whole time when he was doing it i was thinking b]"I don't think he should be using a rattle gun for this".[/b]
Um sorry guys but I use a rattle gun on heaps of bolts that u would consider would not need to be done :)
And i am a "REAL" mechanic and do this for a living,sometimes when it comes down to it it is a matter of time
but saying that tophat bolts would probably be done by hand as they are not that good a quality bolt( would say at max a grade 4 bolt)
Resolution!
So I must say I'm relieved.
The guys have replaced the broken, and resolved the popping issue.
The strut was as Tony said, a piece of rubber missing, replaced that and all is swell!
So very pleased with their service in the end, they just sucked it up and got it sorted for me. Mag and Turbo Rotorua! Those guys there really do love their jobs a little too much though I think :)
