Removing piston gudgeon pin
Ryan
Tis easy..
Don't pull but rather push it out.
If you try to remove the pin from piston 4 do it by pushing through the gudgeon pin access hole for piston no 2.
Do this by positioning piston 2 such that it is just before or just after TDC and you can see no 4 gudgeon pin through the no 2 hole.
Use a long thin flathead screw driver, butt it up against the gudgeon pin and gently tap it out.
Be careful that the no 4 pin dosen't catch on the top of the no 4 access hole as it slides out - this will happen if you are too far from TDC on no 2.
No 2 will be easy to remove now doing the same thing just starting from no 4 access hole - con rod will not be in the way this time.
Repeat for other side.
And pre-empting another question of removing pistons...
Once the pin is out rotate crank a full revolution.
Both piston 2 and 4 will be at TDC.
Push no 4 down the bore and rotate it a minimum of 45 degrees at the same time.
Then do another full rotation of the crank - rod will push the piston out.
Another way is with a large flat head nail. File the lip a bit thinner and then slide it down the inside of the pin, while holding it with vice grips. It can then be pulled out easily
Guest SPANKU
theres a trick in youtube. or if u are in wellington u can borrow my home made tool to get it off... give stoffa a pm for photo. hes got my one at the moment
