2.5 blocks
sultan
As I've posted before, I'm looking at doing a 2.5 motor. New EJ257 and drop in forged pistons is one option i'm looking at for my power target.
But there are other 2.5 blocks - are they all pretty similar? I.e BH legacy. Are there ones that would be appropriate to build a 250kw motor out of and ones that wouldn't (assuming the n/a block was built with forged turbo pistons and rods)? Is the crankshaft a problem? Will it still bolt up to my 2.0 heads? I've attempted to research this but haven't found useful information about the different block types.
If you find a later model (8 bolt) n/a 2.5 block then it should be semi-closed the same as the STI one (my mechanic has one which he got from a wrecker, we pulled the heads off and it was anyway).
The crankshaft from one of these engines will also be fine to use for a turbo application - well it was what I was going to use when I considered building a 2.5 anyway...
i already have 240kw 2.0, it doesn't interest me. i want 2.5 for torque and turbo response
8 bolt n/a block is the way to go then, thanks tony
another thought - will my existing tune be OK for run-in period given that all i'm changing is the shortblock?
 funkytown said:
i surely would do a run in on a motor with a tune from a different capacity engine.
doesnt seem logical at all.
When Nt_a_foz was looking at 2.5 the tune from the 2.0l was going to be good enough for run in.
but id check with your tuner not some people over the internet
Iv only seen open deck late model 2.5 N/A engines?
 caged']
I thought they were all open deck as well (hence why I said "should be" rather than "will be"), but the one my mech has is definately semi closed.... Will try and find out if he had any info about which vehicle it came from (engine was purchased from a wrecker).
Optical grabbed a couple of EJ25 blocks off me last year. One was a dirty old EJ25D from a BG Grandwagon, the other was a EJ25..? from a BP Outback. The old 25D had thicker cylinder supports than the newer block.
