How to wire Orange A/F into Green A/F Plug
smokn4
I can't find it right now, but I know I've got it on paper out in the garage.
I did find this post though...
Looking at the open face of the wiring connector with the clip thing at the top and the wiring pointing away from you....
RH wire is 12V supply
Middle wire is earth to ECU??
LH wire is signal
I used the connector from an orange AFM and pulled the pins out of the green AFM connector and fitted them to the orange.
theres a few more things to re-wire if your plugging a v3/4 ecu into a v1/2 loom.. if your having trouble with the afm its going to be a looooong job
in saying that however if you get it working let us know.. it can be a prick of a thing to sort properly
 smokn4']
[quote name='boostin said:
There isn't. You have to fit an orange AFM if you're swapping the ECU to a V3/4 STi ECU.
or if your ECU is chipped to run the Orange sticker
yer thats one way around it haha
who programmed it specifically for the orange afm? and why? if you can tune your own chips the afm is irrelevant unless you want the larger intake diameter, 90mm i think it is
I found it!
Green --> Orange
Pin 4 ---> Pin 1
Pin 2 ---> Pin 2
Pin 1 ---> Pin 3
All as looking into the open face of the socket.
  • 7 months later...
  • 11 months later...
 smokn4 said:
bumping old thread....
anyone have any more info on this.......tried this and my afm started ticking when on idle???
i used this trick it worked for me no problems. this should be added to the wiring pinouts/threads its a pain to find.
 tydon']
just out of interest what ecu were you using??
 smokn4']
2S ECU 3plug and purple 3pin afm
there is a gain in going from the crappy green air flow to the orange afm
the orange 90mm guy has much more resolution - can get a smoother tune out of it as theres more room to smoothen the tune out
also more head room so u can tune within the resolution - but when it comes down to it u can still tune off a 5v signal anyway
