3 plug to 4 plug adapters, who was making them?
I remember a while ago on here someone was making 3 to 4 plug adapter looms to run v3/4 sti ecu's in early legacys/wrx's, anyone know who that was? looking at a plug in link but its set up for a v4, so if I could find the person making the looms up I would be very happy if they could do me one? can supply the 4 plug and could probly tracki down the 3 plug somewhere as well, or even if someone has a diagram (simple diagram) of how to make one that would be great. cheers
mint, what do you need to make them? obviously a couple of plugs and looms to attack? if i supplied the gear and coin would you make one for me? i really dont have the patience to look at a wiring diagram
You need an old 4 plug ECU and the wiring with plugs from a 3 plug ECU. You need around 150mm of wiring as minimum.
I've only got a handwritten crossover at the mo. I'll have to find it in the piles of crap in the garage and type it out.
