What oil to use?
Hey all sorry for the noob question, but I'm just wondering what Oil should I use for my car, and how much of it? Oh and also type of oil filter.
Its a
Subaru Legacy RS 1996
2.0 TT
Automatic
Just bought it a few months ago, and its due for an Oil change and oil filter change.
Also would it be wise to just take the car and oil to a mechanic and get them to change it? Rather than bringing it to armstrong subaru or what not to do the change?
Cheers a bunch!
Oil change can be done yourself in under an hour with only 2 tools and a bit of patience.
+1 on BC5's choice of oil. Thats what i ran in mine
Sweet so Magnatec 10-40 it is thanks!
How much do I need? oh and what tools do I need keltik? I can just get my mate to help me out. Is changing the oil filter do able aswell? Where do you guys buy your filters from?
Your tire iron will fit the sump plug bolt. And you need a filter wrench to remove the filter.
You'll need 4.5 litres of oil.
Go to your local Subaru parts vendor and ask for the filter and sump plug squash type washer.
Youll need;
At least 4.5liters of oil
An oil filter strap OR a 6inch square piece of non slip foam (makes undoing the filter a shitload easier)
17mm spanner for the sump plug
12mm spanner for the plastic under tray if yours is still fitted
A bucket to drain the oil into
Thats it
i have used magnetic 10 w40 since i rebuilt ma engine 15,000 ks ago and fram suregrip oil filters, found castrol does not get real dirty fast like some other oils ;)
I'm not sure that is a good thing! You want the oil to not just lubricate and cool the engine, you want it to pick up any dirt to be deposited in the oil filter.
I agree that it is a nice feeling when the oil coming out looks almost exactly like the oil that went in though (my GTB is like that :)
 keltik said:
Youll need;
Thats it
hope someone added a Jack and jack stand!
or at least a deep ditch to park over....
NEVER get under a car with just your Scissor jack supporting the vehicle
