Lower spool revs?
cpt kernow
 NotAnotherWhiteGTB said:
You need more displacement if you dont want to change your turbo size, i would agree with Koom and put a dirty v8 in it :) Or a rotary... jk
I dont know what hes talking about.....do you clint? Passing in 5th isnt hard
Subaru have a GREAT system that was installed in Legacy's from 93-2003 called Sequential Twin Turbo providing exactly what your are after CPT
admittedly its not perfect but nothing really ever is....
 Qwerty said:
If its stock then a
catless downpipe will help spool.
Aftermkt boost controller.
Remove snorkel from the intake system
See I did get a helpful answer. I was thinking of a downpipe, do I get it with lugs to plug sensors back into or substitute with resistors.
By boost controller do you mean electronic or pnuematic?
A replacement downpipe should come with a fitting for your O2 sensor.
You could use a pnuematic effectively but ebc would be better.
Passing in 5th - it would depend on the how steep the hill is and obviously what speed your doing. If your passing in a passing lane and you just need to beat one car then i guess its possible.
Im not the best to judge as i run a short ratio gearbox anyways.
i should've refrased, i mean when you're doing 110 @2700rpm and just wanna nip past someone and it won't be long and you don't wanna rev past them so they think 'typical subie driver'. My turbo doesn't pick up till around 2900 but wanted to lower it a little.
