Wheel Alignment question?
grim
I have just had new tyres fitted and did the usual wheel alignment, ballance etc. I found out afterwards that they used the specs for a '07 car, not mine.
The settings used and the correct specs are below, does anyone know if the difference is important or not?
Actual Correct Spec
Front camber L-0.57 R-0.46 -0.127degrees
Caster L6.06 R6.24 5.920
Total toe front L0.2 R0.2 0.000
Rear camber L-1.45 R-1.15 -1.250
Total toe rear L0.6 R0.6 Total 1.2 0.000
i'd leave the front toe where it is as they've increased the front camber and will compensate for the extra camber.. as for the rear toe i'd drop it slightly to about .3 or zero toe it, subbies like zero toe but with more camber it ok to have a little toe as it spreads the wear across the tyre rather then the edge.
ps : It also depends on if their alignment reads in 60 mins or 100 too... and if your spec measurements are also done to 60mins or 100 too.. that does make a difference.
