Harmonic balancer
gazzy2000
Hey,
Started the car this morning only to hear a clicking noise, on closer inspection the harmonic balancer (crank pulley) is munted the rubber is totally gone.
I have one off a v3/4 STI thankfully. Some ppl say they are balanced for YOUR engine, i read they have nothing to do with balancing of the crank shaft itself, they damper out torsional vibration using their mass and the rubber for energy displacement.
Some questions:
- Some ppl say they are balanced for YOUR engine, is true??
- are STI ones better contructed than standard? i.e. are ej20 H/Balancers all the same?
- when they crap out like that can they do any damage to your engine?
cheers
 funkytown said:
if its clicking and wobbling... PLEASE check the keyway.. Mine was f***ed like you describe
as was with mine it has come loose a little and the keyway was munted (that keeps it straight and true) and this meant new crank
:'( i hope this is not your issue..
YIKES! mind you i can clearly see the rubber is gone..
Slightly off topic - I've just had a look at mine, its not a factory type with the rubber it looks like its machined for a solid billet of aluminium, would this do damage to the engine eventually? I'm sure the factory harmonic balancer should be on there for a reason, right?
this might help http://en.wikipedia.org/wiki/Harmonic_balancer
probably a GFB aftermarket one
