99 B4 Intercooler is spewing Oil
sylus
This is normal.
The crankcase vents the engine blow-by vapour via the intake system (EP/Emissions requirements)
A small amount of the oil in the vapour condenses out as it cools (surface contact) and coats the intake system including the IC (reducing its efficiency ) the majority is burnt via combustion chamber. The oil accumulates with time and the amount deposited increases as the engine wears due to increasing blow-by.
One way to minimize this is to install an oil catch-can. This acts as a oil condensation trap between the crank vent and the intake system.
Grimmspeed released one with the trap located in the oil filler cap.
