HKS SSQV Issues....Its not working at all
stira
Is it externally venting or plumbed back?
What are you not sure about with its installation? They have a vacuum line from the manifold plumbed to the wee nipple and they go onto the 36mm (or 19mm) hose that is somewhere on the pressure side of the piping.
Does it make a squeely sound?
Sure its not a bung vf23 that's leaking oil that is the reason for oil in your intercooler?
Sorry, defiantely a bung VF23 thats putting the oil into the intercooler. This is due to the HKS valve not releasing anything.
Its got one tube going to the toip of the manifold, Im suspecting thats not right?
No noise at all from the HKS valve
Which vaccum point are you using?
The vacuum nozzle on the SSQ requires a step down in vacuum hose diameter.
Cheap ones can seize.. sure it's genuine?
Looks/sounds like its installed correctly.
Tried sucking on the hose to see if you can get any movement from the piston at all? Sometimes can move it enough to be able to feel it starting to move.
Also check that the hose doesn't have any blockages.
 Koom said:
I wonder if its leaking? Cause it sounds like everything else is doing what it should. Does the car make boost nice and early or is it slow to come on?
Seems to be ok, but ive never had it going well for more than a day so its a bit hard to tell. I was wondering if those other holes should be plugged to give more vacume?
Guest boostcut
having no bov wont really do damage as such, well not in a short period of time, im sure you already know but the idea of a bov is to stop the compressor from stalling, causing a lag between gears. in the long term it can probably cause damage to compressor, but i wouldnt say it would cause it to leak oil...
Guest boostcut
a high idle, because of the vac leak, it will run rough off boost, have a lean missfire on boost possibly and a higher co2 reading than normal.
