gearbox side seals
gazzy2000
 CUDDAS said:
Hey Gary i just did some in my box's i got the seals from armstrongs subaru chch for around $14. a seal & i used a 32mm socket & small soft hammer to remove & fit, they are directional L & R sided. my box's were already apart when i did them tho
cool thanx, least they are cheap to do :)
wud just like some pics or intructions to get to the seals on the box itself
I am sweet with getting the CVs off the axles at the g/box end etc
I also believ there is an o ring aswell as a seal?
ahhh, just pull the seal out without pulling the cap off, and you can do it just by dropping lower ball joint, swinging hub out of way and pulling the seal out....
aah yeah removing that whole unit will affect the crown / pinion backlash adjustment eh? i.e. DONT change it?
well i took it off anywho, took heaps of pics, used a dot punch to mark it and a sharp blade on one of the fins to mark how far it (the retainer) stuck out, then counted 5 & quarter turns
both sides were leaking, reckon the g/box shop musta put the seals in the wrong sides (its got $1800 worth of reciepts)
fingers crossed
