1992 wrx td05h standard?
kook
To be honest, u haven't even purshed the limit of ur current turbo. The current one will max out ur injectors. So first upgrade ur fuel pump, ecu, bigger injectors ie yellows at least and then you should start looking at rebuilding ur current turbo with a 18g or 20g. I have had 238 kw atw with an 18g td05h on mine. Even then ur engine if it is just a 1992 wrx probably won't be able to handle the top end anyhow unless you have a forged rebuild.
