1996 GTB Battery CCA
B_Man
as a big as u can fit tin the hole
i doubt it will be battery issue unless it is over 5 yo
my guess would be either wiring to starter motor,especially the big engine earth
or the starter itself,
I had a similiar issue in my landcruiser,tried running dual batteries (2 x 800 CCA's = 1600 CCA's) still slow :( upgraded all wiring,still slow,sent starter motor away for a rebuild it was stuffed, fitted new starter motor NOW it cranks so fast it could almost drive on the starter :)
450 should be fine in an everyday 2.0l car, what surprised me with batterys was that i had to go to a 600 for starting my boat (90hp johnson v4 2 stroke) a 450 had no chance in hell of starting it, and it seems a reasonably small motor?
i think the factory spec battery, according to the guys at century yuasa is a 55D23LMF which is 530CCA. that is the century part no, it maybe cross-referenced to others. nb: all the bosch, century, super works, etc... battery's now come from the same factory in korea, and they simply slap the stickers on them. i know this as i have bought several directly from the distributors.
century used to be good when they were made in australia, the old yellow/blue ones.
so exide red ones maybe the goer now.
i used to buy the slightly bigger 58MF at around $80ish + gst. a little cheaper than the factory one.
didn't realize the starter motors drew that much current, even for a split second. i guess that's why the power feed isn't fused from the battery.
