TD05 vs. VF22?
Ryan
I run a td05 with 18g compressor wheel. Have 220kw atw at 21psi, still more in it yet due to a fueling issue that Im currently getting rectified plus a few other tweaks to come. Unsure with the vf22's on how high they go, the highest i've personally seen is 218kw atw but also you have to take into account if its a hub or rolling road dyno etc etc since dyno figures can change quite abit depending on which dynos u jump on.
They are both similar in regards to the final outcome u want, a td05 with 20g compressor should b able to net u more power then the vf22 but at the cost of lag. Im unsure on pricings for rebuilding a vf22 but I understand with a td05 the cost isn't actually that much to get them rebuilt if things go awry.
