Electronic boost control question
WRXONP
After watching a few cars on the dyno running boost solenoids you can see on the graph that the boost is anything but stable ? Is this the solenoid cycling ? Am wanting to know if an after market controller on an external gate would do the same or would it be stable ?
u can get smooth boost with factory solenoid as well bro - just needs to be set correctly
see blakes psi graph and u will see its smooth
an electronic one tho is easier to set and get a smooth stable psi as its fairly smarter - depending on which sort u get
have seen it stable both on internal and external
but once u put a proper electronic one u will have the best setup using the external and im sure hols boost very steadly
cant wait to see ur one next dyno as looks like u have some good plans for it.. ;D
Have used both tap and electronic
If u want just a single boost level and have got moderate levels of psi then tap works very well
Electronic ones seem to hold higher boost levels better but maybe not good to force turbo too hard
Electronic ones claim to bring in boost earlier but for the difference in price a tap is not that bad anyway
Electronic ones are best if u want something more sophisticated like gear based controller
Anyway in summary a tap is good for what it does and can do 90% of what a electronic one can FO a fraction of the price
If u are pushing closer to turbo limits then get electronic else Tap is sweet
How much u scored that for bro
They are very good and easy to set
Seriously easy to set and soooo hold boost rock solid
Have had that on 2 different cars and fitted to few more and always have had very good boost control with them
Download the manual from net or let me know and can send a link
And ya they have a switch for external gate and all
U will love it bro
haha got a question though bro
Since the HKS evc4 runs in KPA i still want to run my PSI boost gauge...
it says in the instructions to run the map sensor for the EVC (to read boost pressure) should run off a non interupted vac line from the intake manifold??
i have run out LOL i have one port for the fuel reg.one port for the ecu map sensor.one port for BOV and the other port for the boost gauge...
what shall i do about this LOL can one be tee'd up and still function all good??
About 18 psI bro . . . . Shit yea mean difference . . . It spools allot easier and when you plant it the boost comes on allot faster and just hits peak boost and holds it strong as . . . So easy to install and to set boost is too easy lol . . Definitely recommend these for any one who wants a electronic boost controller thats not real confusing
 WRXONP said:
About 18 psI bro . . . . s*** yea mean difference . . . It spools allot easier and when you plant it the boost comes on allot faster and just hits peak boost and holds it strong as . . . So easy to install and to set boost is too easy lol . . Definitely recommend these for any one who wants a electronic boost controller thats not real confusing
mean bro. carnt wait to c it in action hahahaha
It hits around 1.2 bar on the digital display and only drops around 0.05 bar through the whole rev range . . And I get 1.2 5 to 1.3 bar in 4th gear . . . The boost drop of 0.05 bar isnt noticeable on the boost gauge but you can see it on the digital . . . . . But my lines are quite long . . Im going to get a niple put in the piping closer to the waste gate so that the hoses are allot shorter but it still controls really well :) the boost comes up really fast and hits peak hard and holds strong
Good stuff bro
Gotta admit it's bloody good ay
For set and forget control cNt think of any better in terms of setup and use
Try and set the scramble mode to say 19.5 and use that only in mid range
J will love the hit it brings bro
Can add external trigger on scramble mode so makes it real easy
