subaru rear 2 pot dimensions ?
need a few dimensions only if you know please dont answer if you dont knw as need exact measurements
firstly need the centre to centre on the mounting hole
then i need the distance between centre of calliper (where rotor would run ) and the mounting face of the calliper
cheers
which ones? front or rears?
not all 2pot fronts are equal either :P
260mm disks and 297mm disks iirc (260 wont be right measurement but is close)
edit then I re-read and those points should be the same on all disc's/mounts anyway...
definitely keen to figure out the answer to this. I assume the fronts are the same so would make sizing up rim offsets easier
