steering knuckle
where the castle nut is on the steering knuckle that bolt that sits in there. it turns when i try do up the nut. is there any way of stopping this? any help would be awesome as this is a nightmare lol
you havent hit the end of the thread of the nut or the ball joint as it should do up with fingers until the nut bottoms out,
you can put a jack under the ball joint and put weight on it,helps the taper seat,allowing you to do up the nut.
Can also use a rattle gun
