installation
danz-rs
What model Sony Headunit do you have??
Pretty sure you just need the RCA cables to run from the Headunit to the AMP + a remote power cable that will tell the amp to turn off from the headunit.
Then you just need to earth the Amp and the wire up the sub.
If you haven't wired the power to the amp then run the power cable from the positive battery terminal to a fuse then through a spot in the firewall to the amp.
