both radiator fans not switching on when upto engine temp
kwikfix
It will be located on the cross over pipe under the intake manifold.
Go to the driver side turbocharger look down to the crossover pipe and you will see it plugged in.
I'm not too sure about twin-turbo model's, but you will have to remove quite a bit in order to get a socket down there.
It screws into the crossover pipe.
thanks.....sounds like a sunday mission ;D
Are you sure the engines getting hot enough to need the fans
some systems operate fans on at 95deg with 90deg being switch off temp and some others are at 105deg ON 100deg off
