01 GTB climate control dim??
kiwisurf
Hey
I have a 01 Rev4 GTB wagon.
Is the display on the climate control supposed to brighten when the lights are turned on?
During the day if i have lights on its very hard to read.
Theres a dimmer control on the indicator stalk but that only controls the dash cluster brightnes?
Cheers.
when you turn the lights on it all dims. so while the air con is on push and hold down the off button for 2-3 seconds and should beep once and go bright. only the air con will go bright not the radio. you will need to do this each time you turn the lights on and off or start the car its not a full time preset
+1, done for those that drive with lights on during the day
