RS to GT ECU Swap
Andrew NR
I've only just found out that the BF Legacy GT only has 146kw stock instead of 162kw like the Legacy RS of the same year.
Is it possible to put an ECU from an RS into a GT without any other modifications to increase the power output?
There is much conjecture about the outputs from both.
What year is it? If its a Series 1 then an 8 bit chip would be the best option, if its a Series 2 then a 16 bit board is what you will need.
The only difference between a GT and RS engine wise is the Turbocharger.
Subaru Legacy Generation 1
Series 1 = Non-Facelift
Series 2 = Facelift
It has been mentioned on here before but I'll say it again; Series 1 has an 8 bit ECU and Series 2 a 16 bit ECU.
