Help please!, Car wont start!
Volcanix
so im wondering what is making my car wont start, it cranks over fine, has the usual slight whine(very slight) of the injectors priming but its just not firing, it just continously keeps cranking with No sign on life?!
Never had this issue b4 and it was working totally fine untill i parked it in my garage b4 the snow on monday now it wont start!
ive tried a jump start with a push but that didnt work
any ideas? i need help!
 Volcanix']
[quote name='Dvnt said:
mine has done this as well had no cel codes up, i changed the crank sensor and hey presto its going again ;D
is that hard to do?, never done it and its super frustrating having no car :(
its under the alternator. one belt off, alternator out and there it is.
 Volcanix']
nope just a 10mm bolt and its out and dont even need to take belts or anything off
 Divine said:
I had this once, and also have a BD5, and I kept stamping the accelerator when it was turning over then it went.
yea i spent a good 10-15 min cranking (in periods, not continously) with foot down sadly to no avail, my gut instinct tells me sparkplugs but i think thats a pig of a job
 Volcanix']
Spark plugs aren't too bad to do. To do my WRX i just removed the pod filter to get to the right hand side and the battery and washer bottle to get to the left.
welll thanks for the ideas, ill head out tomorrow and attempt to do the crank sensor, and if its not that then i might pay someone to fix my sparkplugs, lol
and if theres any other ideas Please feel free to tell me cuz this has me stumped.
Buy your spark plugs from 41, you'll save a fuck load of money! I found out too late unfortunitly
 Pelvin']
Buy your spark plugs from 41, you'll save a f*** load of money! I found out too late unfortunitly
Where is 41?, is it in chch?
 Volcanix']
http://www.clubsub.org.nz/forum/index.php?action=profile;u=407 pm Mac he'll see ya right
codes?
after cranking (and car not starting) do you still hear the slight whine (fuel pump ) for 1-2 sec's ?
If yes then crank sensor ok
if no then crank sensor NW
Also are the cooling fans running continuously with ign on... if so the coolant temp sensor failed
note only cam/crank and coolant temp sensors are used by ecu to initially to start engine
 Ichi Ban said:
codes?
Hey thanks for that! :D
No codes unfortunately as i dont have a code reader/it never put a cel up, went just before to test what you had suggested and blow me down the flipping thing starts! but like it starts with its usual 2-3 cranks and fires but makes a weird creaky/cracking noise and the engine heasitates for 1-2sec then goes into normal idle, revves fine etc, but that weird noise on start up is worrysome.
As for the cooling fans they arnt on, with ign on,
