oil pump for modified engine
rex-leggy
 Stoffa said:
Same big end clearances as mine, just a little tighter on the mains.
Is that a 75mm stroke 2.2 or a custom 79mm stroker?
let me know if you need a shim, i've got about 6 oil pumps in my scrap pile.
p.s loving a technical discussion thread without someone being abused for being a muppet :)
Yea its (sorry ::))79mm stroker did that because of the price of rods.
Sweet mate i have about 3 but ive never looked inside the pump to see whats in there i assume the shims are all the same size?
:o dont jinx it :D
 Al_baru']
[quote name='rex-leggy said:
the car will see the track as much as i can but will mostly be a weekend car..... unless i get serious :D
/quote]My car's seen a lot of weekend track time (not so much recently) and the baffled sump done the trick. Other than that it's just a normal sti engine.
Thinking about it some more it's probably got much less power (169kw) than you'll have so maybe not so helpful. ???
Your always helpful Al ;)
I have no idea what ill come out with but the possum link is going to restrict me id say.
I thought about getting a flash sump but then decided to go with a twin scroll sump (from my research there good) that even comes with pickup and dipstick .
only thing is i need a windage plate .
i found this
http://www.iagperformance.com/shopping_cart/proddetail.php?prod=EJWT&cat=142
