BE5 Gearbox and center diff problems, what are my options?
Jono24
Hi guys,
My 98 BE5 Subaru Legacy B4 manual has done unrepairable damage to its gearbox/centre diff.
The mechanic working on it is struggling to find parts for it (he found one down south).
Can anyone tell me what the best options are and are there any other gearboxes/centre diffs that will work with my car (ie from other models).
thanks guys
 Jono24 said:
Hi guys,
thanks guys
Tell him to look harder...
Roscoe's, etc.
Your model can also use the g/b from all BE/BH models manual
 pl0x said:
Could get a earlier model center diff (pre 98) as long as you get the earlier rear housing/transfer case as well
This is the best option too IMO
+1
a lot more robust unit
Hey thanks for the quick response, so the gen 2 facelift center diff is stronger? can i us the whole gearbox (bellhousing to rear of center diff) and bolt it up? they use the same 4.444 final drive ratios don't they? any idea if the front driveshafts use the same spline pattern? thanks
roscos are expensive try jeff at wrex in chch you can get him threw clunies subaru in christchurch phone book they were down leed st. hes got a lot of stuff. if not you can contact me and i can put you onto someone else that rebuilds at home get hold of me threw this link http://www.trademe.co.nz/Browse/Listing.aspx?id=390698307
