looking at legacy b4 2001
mondo
Make sure check engine light is present and working. Watch for any hesitation through the revs,except for flat spot about 4k rpm-thats normal and you'll get a big shove in the back once youre through it. If boost gauge fitted you should get .8 primary and 1.1 secondary on right fuel. Listen for clunks/knocks from drivetrain. Make sure you get to start the car from cold-be suspicious of car having been warmed up before you view. Look at heads for oil leaks. Search on here for how to check for fault codes.
