2&4 ringland issue? rebuild help?
Disruptz
Drivers Side-------Passengers Side
[-----------Fire wall------------------]
[3]=Cylinder(120,120) [4]=Cylinder(100,100)
[1]=Cylinder(120,120) [2]=Cylinder(90,95)
[-----------Front of Car--------------]
It seems like 4 & 2 are hit with ringland failure,.. Soo, now what do I do?
current engine is the V7 EJ207,
Do I need to get a new short block? or how do I fix this? :-\
 pappu said:
What's normal?
Mine was 147 I think on all pretty much same-ish numbers on all
Mate reasons it's important for all to be within 1-2percent of each other than final number
Yeh, well that's a 17% difference alone going from 120->100psi on 4, let alone 2's 90psi... :-\
(it's still some pressure, I guess no pressure would be alot worse!!, as iv;e read some people have had almost next to nothing)
I presume Iv'e been driving like this for atleast a year, ;D
So, parts roundup? (so far)
- CP 92.5mm 8.0:1 CR Forged Pistons...
- CP EJ20, H Beam Rod set. (may aswell once the engine is pulled) -( or new rod bearings)
- Gasket - Subaru EJ20 93mm, 0.78mm
- CP Piston Ring Set
